Saltar al contenido principal
iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben ser reemplazados como una unidad. GSM / 8, 16, o 32 GB de capacidad / Modelo A1332 / Blanco y Negro.
Preguntas 2375 Ver todo
Is it possible to replace only the glass on the iPhone 4?
My iPhone 4 fell from my hand one week after I bought it. The front glass was completely broken, but since I am using the glass protection sticker I am able to use all the functions in the phone, even the touch screen doesn't have any problems.
Please let me know if it is possible to replace only the front glass (without LCD). I have checked with a service center and he said the glass and LCD panel comes together and it costs almost 30% of the phone cost. Also please let me know is it safe to use the phone with broken glass
Es esta una buena pregunta?
Puntuación 2
4 comentarios
I found some dude who sells both white and black iphone 4 replacement parts, as well as black to white and white to black conversion kits.
I've bought both a white conversion kit and a spare white screen assembly, and i can only say good things about that trade.
If you are looking for iPhone 4 Replacement parts, he's a great resource :)
Here is his ebay account: http://shop.ebay.com/dareeude/m.html
- Hope you find what your looking for!
- de
I have iphone4 i dropped it and the front screen fell out u can see the sliver part where screen was and back all smashed cant it be fixed
- de
Yes it's possible with warranty and flexible price
Please contact on this WhatsApp +97433661455
SHURUQ MOBILES
Doha Qatar
- de
Iphone ( 7+ ) Front Broken Glass Change ( 650riyal)
Iphone ( 7 ) Front Broken Glass Change ( 500riyal)
Iphone ( 6 s+) Front Broken Glass Change ( 350 riyal)
Iphone ( 6 +) Front Broken Glass Change ( 200 riyal)
Iphone ( 6 s) Front Broken Glass Change ( 250 riyal)
Iphone ( 6 G) Front Broken Glass Change ( 150 riyal)
Iphone ( 5 ) Front Broken Glass Change ( 90 riyal)
Contact:- Shuruq mobiles
Doha Qatar
WHATSAPP: +97433661455
- de
Agregar un comentario
6 Respuestas
Solución Elegida
You could buy just the glass, but how do you adhere it to digitizer? The glass front panel is sold with the digitizer for a reason, don't be fooled by a cheap option of just the glass.
There is no real problem continuing to use the phone in the short term ( Depending on the extent of the break), but fixing the broken glass will stop the digitizer/LCD from being damaged further.
Also check to see if your insurance covers this damage...
Fue útil esta respuesta?
Puntuación 7
3 comentarios:
not sure what the down vote is for- you can buy the glass, the digitiser and the lcd separately. I am advising you not to do this.
if someone can detail how you would swap the parts without breaking any other part of display that would be helpful.
- de
Thank you very much for the advice.
- de
Well ... you're right but to adhere LCD to glass (digitizer) you should buy also UV glue and UV lamp which means that cost will rise for 15$ ... also you have to separate LCD from the broken glass (heat gun will be needed - more $$$) - this is very difficult, take some time and risky (you have just only one chance)... After separation - if your LCD will be still OK - you should remove glue which remains on your LCD ... again - time consuming, risky, need some chems like alcohol, some cleaning towels (don't know what kind of) - it means more and more $$$... Adhering both parts together need also some skill and you must be careful to avoid wrong placement! Conclusion: GO AND BUY WHOLE SET FOR 40$ ... no discussion... :)
- de
Here is my kindly suggestion, please check!
If there are have some problem with your digitizer or lcd, you'd better to change both of them.Because for the iphone 4 digitizer and LCD are very difficult to seperate. If you can not good at it, please do not try in case damage your phone.
Besides, if you like to change the digitizer, you'd better choose the digitzer with metal frame.Because it difficult to install.
Thanks
Hope it can help you!
Puntuación 3
1 comentario:
What is price of iPhone 4 complete panel in pakistan
- de
i own my own iphone repair store and to answer your question its YES..BUT...
yes you can replace the just the glass, BUT its no point really, unlike the 3g and 3gs where just replacing the glass will do.' on the iphone 4 the glass and the LCD are actually glues together to form one peice. and is nearly impossible to seperate the two.
so please dont buy jsut the front glass panel. you will need to buy the whole front assembly in order to do your repair. the best place to buy is from Amazon. they offer multiple prices and you can see which one ships closer. dont buy one too cheap, you get what you pay for.
Puntuación 3
Yes it is possible to replace glass only on iphone. It requires an lcd separator machine. I found some useful lcd separator machine reviews at www.lcdseparatormachines.com. They also have some tutorials on how to do the repair.
Puntuación 1
1 comentario:
That's a bad promo man.. If you're gonna use THIS to Rep your product at least make it sound enticing.
- de
Hi you can buy new screens for iphone 4 for about £20 ish but you would need to installl yourself.
Puntuación 0
Only zen man can do this properly, best option is to replace the set, damage to any of the part is inevitable (seperated out as 3 parts.,)
Puntuación 0
Añadir tu respuesta
SHAJEER estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 122,340
