Saltar al contenido principal
Guías para la versión LTE del iPad Mini 2. Anunciado el 22 de octubre y lanzado el 12 de noviembre de 2013. El iPad mini 2, originalmente conocido como iPad mini con Retina Display, tiene todos los píxeles del iPad Air en una forma más pequeña de 7.9 " factor.
Preguntas 61 Ver todo
The touch screen does not work on iPad Mini 2 LTE
The touch screen does not work, I have changed the glass and it has stopped working the following week.
Perform the change of touch glass by a fall. The glass broke. I made the switch and the tablet worked perfectly for one week. But one nigth after loading it ... the tablet stopped working the next morning.
The first option is a reboot ... it did not work. The iPad's touchpad did not work after restart.
I have to add that I replaced a new glass to rule out that it was not crystal failure. I think the error may come from the motherboard.
I took all precautions for repair. I disconnect the battery and all the terminals following the indications of ifixit.
The iPad, It ran for a week perfectly, but stopped working the touchpad. The iPad turns on and can connect to iTunes, but I need the touchpad to unlock it.
Can anybody help me? Anyone have a previous solution?
Thank you so much.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Have you tried a restarted? If you have not try this: Simultaneously hold down the start button, in the landscape position middle of the right hand side, and the off button, upper left hand edge. Hold for fifteen seconds. The screen will go dark and then a white Apple with a bite out of it will appear on a black screen. It may take a few minutes, then the start screen appears. Sign in and see if all systems are working as they should.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Yes, the first option is a reboot ... it did not work. The iPad's touchpad did not work after restart.
- de
this is probably the touch ic chip. BGA soldered, not replaceable by you or me. take it to a BGA repair service.
Puntuación 1
Añadir tu respuesta
Enrique estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 1,209
