Why does my phone turn off when unplugged from charger?
I have an iPhone 6 that has been repaired once (change of a broken screen and some chip).
It's stuck on 1%and doesn't go any higher.
When I unplug the charger it turns off even if it's been left all night.
It keeps switching on and off.
As long as it's in the charger it works fine.
It doesn't switch on if I plug it in to my computer it keeps showing the apple logo then a black screen on and on.
I at least wanted to back it up in case of a reset.
Sometimes when it switches on it gives 100% but then shuts down quickly even if plugged in.
I get the sign that it's charging but it doesn't increase.
Es esta una buena pregunta?
7 comentarios
I also have this problem but my phone has never been repaired
- de Natalia
I think you might have a faulty battery, replace the battery and see if that Fix's your issue.
- de Dr Gizmo
i have iphone 5s and it is shut down for 1 month and currently it is connected to a charger but doesn't open? what happened to my phone? Give some solution please?
- de Afrin Naz
what might be the problem with my phantom 6 plus when someone calls it shuts down but if its on charge it doesn't go off
- de sarah manesh
@sarah manesh Your comment is indeed a question and it's not in any way related to an iPhone 6 which is the topic of this question. If you expect to get an answer post a proper question including as many details as you can about your device history. Posting an out of place comment attached to a random question won't get you anywhere.
- de arbaman
Mostrar 2 comentarios más
