Una consola de videojuegos producida por Sony Computer Entertainment, anunciada por primera vez el 20 de febrero, en 2013 y lanzada el 15 de noviembre en 2013.
Preguntas 768 Ver todo
PS4 CUH-1215a optical drive replaced, still won't accept discs, help!
I was playing playing GTA Online happily one night, turned system off via controller menu after closing all applications, went to bed. Went to work the next day, got home, turned system on, tried starting GTA, and got a disc read error. Powered off the system, waited a few minutes, and powered back on. This time I got a message that the disc wasn't inserted, even though it was. I assumed the optical drive crapped out on me, since it wouldn't eject or read the discs... In fact, the optical drive was making no noise at all. So I ordered a new optical drive from eBay. While I was waiting for it to arrive, I tried all the fixes I could find... Booting into safe mode and rebuilding the database, reinstalling the system firmware, to no avail... I haven't tried restoring to factory settings yet, as my wifi is painfully slow, and I don't want to have to wait weeks for the rest of my digital collection to re-download.
Got the new optical drive in, and replaced it using ifixit's handy guide. :) I made sure all the cables were firmly connected, reassembled, plugged in, and prayed... new drive made no noise, and wouldn't feed the disc in. Crap. $100 wasted. I tore EVERYTHING apart this time, and looked over the motherboard, all the ribbon cables, etc... The ribbon cables all LOOK fine to me, no folds or damage other than the usual "guiding" folds. Checked out the motherboard, I see no missing or loose pieces, no scorch marks as if something overheated, nothing... Granted , I don't know EXACTLY what I'm looking at, but everything looked okay to me... I'm at my wit's end... I don't know why 2 optical drives are dead in the water... Do I need to just suck it up and order a new motherboard, or is there ANYTHING else I can try before shelling out more money? Help, please!
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
I'm having the same problem. I can't find a drive board info to order a new laser I also have the CUH-1215A have taken my console down to the bone but nothing in need of advice
por
Agregar un comentario
4 Respuestas
Solución Elegida
Unfortunately there is likely nothing else you can do but buy a new motherboard. The one thing I will say is to look very closely at the part of the motherboard that is used for the disc drive. It is the part where the ribbon cables plug in. I've fixed several of these that have corrosion in this area and made the disc drive not work.
If that area looks nice and clean it sounds like you've checked everything else that would cause this type of problem so it may take a new motherboard to fix it.
Fue útil esta respuesta?
Calificación 3
Comentarios:
I was wondering... What is the button battery on the motherboard for? It's located directly under the ribbon cable connector that connects to the motor for the disc drive. Is it possible that the battery is shot, and no power is getting to the motor?
por
No...that battery is the power for some of the memory. It has nothing to do with the operation of the disc drive. The power for the disc drive comes directly from the motherboard.
por
Ah, I see. I guess I'll just bite the bullet and shell out for a new motherboard then. Thanks!
por
No problem. Hopefully you find a good one for a good price.
por
Is not quite that simple you will need the old drives oem board to come over to the new Blu ray drive the board will tell you if it is a BDP 10 or BDP 20 you will have to order the corresponding part and use the existing board in your new disk drive as the Board is married to your motherboard.
You said you followed the directions exactly, so I'm guessing you swapped out the board on the optical drive, right?
Calificación 1
Comentarios:
Actually, with the 12xx series models, there is no daughter board married to the mother board, so there is nothing TO swap, other than the drive itself. The only board attached to the 12xx series model drives is the PCB control board, basic eject button control.
por
Brandon is right. I finally figured out why mine wouldn't accept discs same thing with the older models the apparatus holding the arms for the disc drive has a special way that it slides on to the disc drive
por
Try replacing the eject button you can get them for pretty cheap so even if it doesn't work at it won't be to much trouble.
Calificación 0
I have unfortunately the same problem with reparing this week already. Really frustrating.
Calificación 0
Comentarios:
One thing I can say I had that problem for about a month until I meticulously F***** with it there's a special way the disc drive goes back together particularly with the silver piece with the arms for the disc try sliding it in front side first that worked for me that's on the 1215A if that doesn't fix it then that plate could be warped possibly
por
Añadir tu respuesta
Brandon Martel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 40
Últimos 30 Días: 228
Todo El Tiempo: 4,408
