Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3904 Ver todo
Unresponsive screen and black lines
Hey,
My 5s was connected to the computer when we had a power cut. first the screen had some black lines and now the screen has 2 black patches and the screen doesn't respond to touches. where do you think is the issue and what parts should i buy? I'm trying to fix it myself (first time)
regards,
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Comentarios:
Either the screen needs to be replaced or you have a board level issue which is pretty much as bad as it gets.
por
Agregar un comentario
Kits de reparación de iPhone X
¿Garantía vencida? No te preocupes, tenemos la solución.
Comprar Ahora
Comprar Ahora
1 Respuesta
If you have someone call your phone, does it still vibrate/ring? Or does your computer recognize it when you plug it in through USB? If so, then you'll probably just need to replace the screen assembly.
Find an LCD/Digitizer assembly for the 5S, iFixit sells good quality ones (the cheap ones can cause major problems and in my opinion are a waste of money). I doubt the power outage caused it, as it sounds like the LCD is damaged. Black lines and splotches are typical of a physically damaged LCD.
Fue útil esta respuesta?
Calificación 0
Añadir tu respuesta
sachith senanayake estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 28
