Saltar al contenido principal
La computadora portátil Toshiba Satellite E45-B4100 se lanzó al mercado el 4 de marzo de 2015. Tiene una pantalla de 14 pulgadas y pesa 6.8 libras. El número de modelo es PSPNAU-001002.
Why won't my laptop charge?
My laptop isn’t charging and is not registering the power source. What do I do?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Plug in the AC Adapter to the laptop and check display for indication that the laptop is charging. Ensure the output value of the adapter matches the input value of the laptop. Ensure adapter works in separate test by charging a different Toshiba E45-B4100, or a different compatible electronic item.
Turn the laptop off, unplug, and remove the battery for twenty seconds. Now plug in the charger to the laptop from a working power outlet. Check to ensure the green power icon is lit and allow the laptop to charge overnight.
If the laptop still fails to hold a charge then you will need to replace the battery. Instructions on how to order a new battery are available at: https://support.toshiba.com/support/serv...
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Delaney estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 2,800
