Saltar al contenido principal
El Nissan Altima es un automóvil de tamaño mediano fabricado por Nissan, y podría decirse que es una continuación de la línea Nissan Bluebird, que comenzó en 1957.
Preguntas 152 Ver todo
NISSAN ALTIMA 2006 2.5L engine shaking
for some reason last night I turned my car on it was shaking and the car engine sounded weak like if it was going to turn off while I was in parked gear. once the car warmed up I put it on drive I can still feel something from the engine was shaking and the service engine soon yellow light was flicking until it stayed on. this morning I turned the car on no shaking and the service engine soon light went off, any idea what can cause this shaking coming from the engine?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
if your car was shaking it was probably not running on all cylinders . Check to see if the computer threw a code and tells which cylinder was the culprit . If you don't have access to OBDII code reader then head to an auto zone or parts source and they'll read it for free. Odds are one of your coil packs is starting to fail it will tell you if there is a problem here and which pack to change. Hope this helps
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
manny gomez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 12,946
