Saltar al contenido principal
Lanzada en abril de 2011, la D5100 reemplaza a la D5000 como una de las cámaras DSLR de consumo populares de Nikon. Cuenta con una lente Nikon F-mount reemplazable.
Preguntas 53 Ver todo
I can't turn my Nikon on
I just bought my Nikon and after a couple weeks of using it, I tried to turn it on again and it won't come on. I already tried buying a new battery. Sometimes when I turn it on a sing legreen flash from an indicator in the bottom right of he camera will come on but nothing happens.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Do the electrical connectors in the camera where the battery connects to look clean, no corrosion on them?
- de
Agregar un comentario
1 Respuesta
you've just bought a new battery so we will rule that out assuming its a genuine Nikon battery and not some cheap 3rd party copy.
the first thing to do is give the battery compartment a good clean, making sure there is no dust, debris or corrosion preventing a proper contact with the battery.
Next you'll need to open up you camera and check the connections between the battery and motherboard are good.
you can follow this guide to open up your camera
Nikon D5100 Motherboard Replacement
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Miles tiller estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 1,981
