Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Huawei Ascend Y600 Android smartphone features a 480x854 display powered by a 1.3 GHz processor. It was released in June 2014.
Huawei y600 got wet
What is the solution when mobile phones got wet?
Es esta una buena pregunta?
Puntuación 1
1 comentario
Do not try to power on and remove battery asap. then follow Jimfixer answer.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Clean every connection with a soft toothbrush. As well clean the logic board; use a 99% isopropyl alcohol for all cleaning. Now is the time to start drying out the phone. Set the screen in a desiccant or silica gel leave it in for several days moving it from time to time to get the max effect from the desiccant. Use a blow dryer on a low heat setting to dry the rest of the phone. Only use a hair dryer once you have cleaned the phone completely with the alcohol. Do not attempt to dry the phone if it’s still wet with water with the blow dryer as this only spreads the water. Replace the battery with a new one considers the old ones done. Clean again with isopropyl alcohol let dry and when you think everything is clean and dry reassemble the phone (make sure to clean the contacts on the screen after removing from the desiccant). Once you've reassembled the phone it’s time to power it on. Hold your breath and hope for the best. This may be helpful . Hope this helps
Fue útil esta respuesta?
Puntuación 4
Añadir tu respuesta
arnoldgriarte estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 33
Todo El Tiempo: 549
