Saltar al contenido principal
La cámara modelo Canon ELPH Z3 se lanzó en los Estados Unidos en marzo de 2012.
Preguntas 3 Ver todo
Why doesn't my camera's flash work?
I was trying to take a picture of something that is in a dark background so I tried to use the flash feature on my camera. However, despite adjusting the setting to "flash on" the camera failed to produce a flash for the picture. What may be causing this issue?
Es esta una buena pregunta?
Puntuación 0
1 comentario
Student question
- de
Agregar un comentario
1 Respuesta
Solución Elegida
This issue is quite common in some cameras and the solutions can range from simple to pretty complex. Sometimes the reason a camera's flash will not work is because the battery is already running low to the point where the camera can no longer produce a flash. To resolve this all you would need to do is replace the batteries. If that is not the case and your flash is still not working, then there may be a defective flash circuit in which you will need to plan out an exchange with the company you have purchased the camera if it is still under warranty. Hope this helps!
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Nathan Barros estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 134
