This HP model was released in 2012. Upgrades include a anti-glare 15.6" screen and a finger print reader.
Preguntas 8 Ver todo
When I press the power button, nothing happens.
When I press my power button, nothing happens. How can I fix this?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
My notebook don't switch on the power button only Flickr
por
Agregar un comentario
2 Respuestas
Solución Elegida
  • Is the power adapter cable plugged into the laptop? If so, make sure the adapter is plugged into an outlet and that outlet has power.
    • If this solves your problem, your battery may either be faulty or not charged. Try letting your battery recharge for a few hours then power down the machine. Unplug the laptop from the power adapter and turn on the machine. If it doesn’t turn on, then your battery will need to be replaced.
    • If this doesn’t solve your problem then you may have a faulty power adapter. While plugged into an outlet, is there a light on the adapter?
      • If there is, the cord to the adapter may be faulty and needs to be replaced.
        • If not, then the adapter may be faulty and needs to be replaced.
For more information check the device Troubleshooting Page
Fue útil esta respuesta?
Calificación 0
mybe there is broblem in bower ic so if you can open laptop mybe i can learn you how you can fix it
Calificación 0
Añadir tu respuesta
Samantha Allen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 14
Últimos 30 Días: 68
Todo El Tiempo: 758
