Why will the A button not work when I press it?
I press the A button in a game that uses it and it will not work. How can I fix this?
Es esta una buena pregunta?
The button was dirty underneath so I removed it, cleaned it with rubbing alcohol and repaired it.
Fue útil esta respuesta?
The A button may not work because the connection from the A button to the motherboard may be interrupted. I suggest you check out our button replacement guide.
It's possible that there is something lodged beneath the button that is causing these problems. Opening up the controller and cleaning beneath the problematic button may solve this issue.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 130
- de Andrew Gonsalves
