iMac's display full of stripes, sometimes works, mirroring works. HELP
My iMac's screen suddenly started showing stripes only.
It starts up normally, but I can't see anything, Everything works fine but the screen itself. All it's displaying is just stripes vertical and horizontal. The iMac never fell, nothing ever hit it.
using another display works fine ! The display rarely comes back to normal after hours of working with my external display image
But when rebooting the Mac it starts up stripped again .
I think the display works fine since that it works from time to time, the GPU too since that mirroring works. But I have no idea what's going on if someone can help please
I napped leaving music on the computer, after waking up I found the screen totally messed up.
I wonder if I over used it. I tried everything I can rebooting and so on, nothing works.
Now I have no idea what to do! I'm a graphic designer and I work with it a lot. It never showed any malfunction for two years until now,
I also have no warranty left and I don't trust third parties at all here in Morocco, most are scamers.
Es esta una buena pregunta?
4 comentarios
Just to be clear here some people use the term 'Display Mirroring' when they have a second system which we are using to see what the other system has on it. Is that what you did? Or, did you connect to the back of your iMac as a second display (dual display)?
Here's a bit more of the different display configs: Use multiple displays with your Mac
- de Dan
my fault i thought mirroring meant using multiple displays
- de aminermiss
No issues here ;-} Just trying to understand what you meant.
- de Dan
My imac, of the same model and year, presents the same problem. Spend weeks or months with the display with the stripes. While I work with another display. Then it goes back to working normally, as if nothing had happened and works for a few months.
- de renato
