Saltar al contenido principal
La revisión de 2016 de Apple a su línea de computadoras portátiles dirigida a usuarios profesionales. Cuenta con una pantalla Retina de 15 pulgadas, 2880 por 1800, Intel Core i7 de cuatro núcleos, opciones de almacenamiento de 256 GB / 512 GB / 1 TB / 2TB, 16 GB de RAM y un teclado equipado con una barra táctil. Lanzado en noviembre de 2016. Características del modelo A1707.
Preguntas 258 Ver todo
Is the ssd upgradeable on MacBook Pro 15" with Touch Bar
I purchased a 256 GB model, and wish to upgrade SSD.
Is that possible?
Es esta una buena pregunta?
Puntuación 9
15 comentarios
No it is not. The SSD is soldered to the motherboard.
- de
No, the SSD is NOT soldered to the motherboard.
- de
Alex, the SSD on the MacBook Pro with touch bar is soldered. You can't replace it.
- de
But, could someone un-solder it and replace it that way? Are the parts out there? Just curious...
- de
Mostrar 10 comentarios más
Agregar un comentario
2 Respuestas
Solución Elegida
The SSD is soldered to the motherboard. You will have to return it and get the one you wish or do some very risky de-soldering which has a 1% success rate.
Fue útil esta respuesta?
Puntuación 4
3 comentarios:
IMHO it is not soldered. I saw some openbox videos on 13' model. Are you sure?
- de
Yes! The Touch Bar version systems both have soldered RAM & SSD. Only the new function key model has a removable SSD and its a different interface than what Apple had been using.
- de
Gotta return it!!
- de
Get buyers remorse. Take it back and get the model you need or you may be stuck with it for a couple of years until OWC comes up with a replacement. See their blog here:
http://blog.macsales.com/38440-ssd-in-la...
Puntuación 1
1 comentario:
@mayer - Sorry the new touch version MacBooks Pro's don't have a removable SSD! Here's the poop: 15-Inch MacBook Pro With Touch Bar Has Non-Removable SSD The 13" is no different.
The new function key version 15" MacBook Pro Does have a replaceable SSD! But, its still a different interface than the older SSD's Apple has been using. Which is what your link is about.
- de
Añadir tu respuesta
Yao Meng estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 19
Ultimos 30 días: 84
Todo El Tiempo: 64,361
