Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
1.83 GHz Core Duo o 1.83, 2, o 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
Preguntas 266 Ver todo
2006 Intel iMac wouldn't power on
My 2006 iMac was dead since I had long trip back. I unplugged the machine before I left. Now nothing happened when the machine plugged and press the button (no sound just black screen). It worked fine before I left.
I tried to take apart the machine and all look fine inside. I replaced the logic board battery and still same. But I found once I put on the plug, it has "da da da" sound continually from behind the logic board. It means any part broken?
Thanks for help to save my old Mac.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kit de Destornilladores Manta
112 bits for every fix.
Upgrade Your Toolbox
3 Respuestas
Solución Elegida
Three beeps is a RAM issue. Reseat the RAM and tell us what it does.
iMac Intel 17" RAM Replacement
Fue útil esta respuesta?
Puntuación 2
Just throwing my two cents in here. Almost every time I see one of these machines in a store its because of a failed/failing power supply. After you've tried what Mayer has suggested, I agree with Vincent that it is indeed a power supply issue.
Puntuación 2
Hi Michael !
I would 1st suggest you to try unplugging the machine, holding the power button for 10s then plugging it back it.
I had the same problem with the same mac model. I ended up replacing the power supply unit (iFixit sells that part) and it now works well. Couldn't tell if your computer has the same problem but I'm glad that it fixed mine.
Hope this helps !
Imagen de iMac G5/Intel Power Supply
Producto
$49.99
Puntuación 0
Añadir tu respuesta
Michael Chou estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 67
