Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
Preguntas 39 Ver todo
Replaced lcd digitizer, now screen flashes and wont stay on.
I replaced a cracked lcd digitizer. Now when I hit the home or power button, the screen lights up and I can see everything for a split second, then everything goes black again. It's still on and for that split second everything looks as it should. I've tried disconnecting and reconnecting the flex cables and the battery flex cable, same thing. Everything is snug and seems as it should be. I'm hoping I didn't damage any of the gold connectors. Any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
if you didnt unplug ipad battery before repair you may have also damaged the backlight component. if new screen doesnt fix the problem you will need to find someone who repairs the boards.
por
Agregar un comentario
1 Respuesta
Hi
Try to check the LCD connector with a magnifier. (with a microscope would be better indeed).
Also try to make a magnified photo if possible.
Fue útil esta respuesta?
Calificación 0
Añadir tu respuesta
Jeff Ray estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 13
Todo El Tiempo: 534
