Saltar al contenido principal
Procesador Intel Core i7 de cuatro núcleos a 2.2 GHz (Turbo Boost hasta 3.4 GHz), 2.5 GHz (Turbo Boost hasta 3.7 GHz) o 2.8 GHz (Turbo Boost hasta 4.0 GHz) con 6 MB de caché L3 compartida.
Preguntas 773 Ver todo
Are the speakers compatible with the earlier versions (12~14mid)?
The internal Speakers in MBPr 15" 2012mid are not as good as the later versions.
Mid 15 model sound much better than 2012 version so I am trying the replace the speakers.
From the informations of the speaker parts being sold in this website, I can figure out that 2012~2014 models are exchangeable with each other. But I am not sure about the 2015 version.
Does anyone tried this before?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
As you may see on these 2 guides (for 2014 & 2015 15" MBP retina), They have the same shape, same screws & apparently the same connector. I would say yes, but I could not be 100% sure about it as this information is not provided anywhere (no part on the store, and I've not been able to find it elsewhere).
Reemplazo del altavoz derecho de Macbook Pro 15" con Pantalla de Retina de Mediados de 2015
Reemplazo de los altavoces de MacBook Pro 15" Pantalla de Retina de Mediados de 2014
Imagen de MacBook Pro 15" Retina Display Mid 2014 Altavoces
Guía
Dificultad:
Moderado
1 - 3 hours
Imagen de MacBook Pro 15" Retina Display Mid 2015 Altavoz derecho
Guía
Dificultad:
Moderado
40 minutes - 2 hours
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Seungyeop Lee estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 130
