? cooling fan relay
where is the cooling fan relay switch in a 2012 jeep wrangler ?
Es esta una buena pregunta?
@agent86 ,Bob, the electric cooling fan HI and LOW relays are located in the power distribution center (PDC) under the hood/engine compartment. Fuse and relay layout label affixed to the inside surface of the PDC cover for cooling fan relay identification and location. Also check out the attached link, diagnosing cooling fan problems, good article fuses,relays, fan motor,etc. Good luck.
Fue útil esta respuesta?
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 71
Todo El Tiempo: 23,108
