turn on a pcb iPhone 5, only with the screen
hello, how I can turn on a pcb iphone 5, only with the screen and the pcb connected to a jumper powersupply what is necessary to unite?
Thanks
Es esta una buena pregunta?
Thanks
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 164
4 comentarios
You connect the negative and positive to the battery terminals to start the phone up automatically. It will turn itself on.
- de Ben
what you say is not true. if you connect a power supply to the iphone, if the power button is pressed not start the pcb iphone.
In many videos do a Juper with tweezers and the phone starts that's what NEEDS to know is which esl jumper on without power button.
https://youtu.be/aMPrOmlULuo
In this video the technician is testing a power supply 5c and until you press the power button and the phone starts brand or source consumption by what you say is not real.
a greeting
- de calyd3
Well you won't kill the phone shorting the power button pins on the board, just keep trying to short the pins for lock button connector until you find the right combination.
- de Ben
Esta es la solucion, solo hay que poner el pin 2 del conector de power a masa y ya enciende.
Un saludo a todos
- de calyd3
