Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Guías de reparación y soporte para automóviles y otros vehículos producidos por la división Chrysler de Fiat Chrysler Automobiles US LLC.
Preguntas 127 Ver todo
Chrysler pt cruiser overheating
My 2007 Chrysler PT Cruiser only has 145000 miles on it the head gaskets have been spun and replaced the water pump has been replaced the timing chain has been replaced and it's overheating again why
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
@scareditsalemon , Amber, There can be many causes for a vehicle to overheat, low on coolant, pinched/restricted rad hose/radiator, air in cooling system, bad pressure/rad cap, faulty thermostat, failed gaskets, pump, faulty heat/temp. sensor reading incorrectly, etc.. If you feel it may be the head gasket again, have the cooling system pressure tested by a good technician to determine this. If it is the head gasket again an inferior repair may have been made and if done recently may still be under warranty, and the repairer may be able to rectify the problem and stand behind their work.
Have a good shop have a look, diagnose and estimate repair. Good luck
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Amber Perry estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 39
Todo El Tiempo: 4,449
