Why is my screen frozen?
The screen froze on me while running an app. I tried both cleaning the screen and restarting it, but the touchscreen does not respond.
Es esta una buena pregunta?
The problem is with the Google Play Store app. Try resetting the tablet to factory and do not sign into the Google Play Store. Any app that you need you can get from alternative app stores that you can download or you can go on the internet and search for the specific app by typing it in this way if I'm looking for let's say Yahoo I would search "Yahoo APK". I have managed to download an alternative app store to Google Play and I get all my apps from them. I also root at my tablet using Kingo root and I installed titanium backup to delete all the junk off of it all the kids stuff including parent mode it is now an adult regular tablet and runs great.
Fue útil esta respuesta?
Amazing, beat my head to death trying to fig it out and on a last prayer found this post. Me and my family are so happy now :)
freesf ftrefv can you help me with the rooting I have the Nabi 20 and the 24 they both do the same thing. The 20 is a mess! it will freeze or randomly turn on and off. I also can not up plug it from the wall as it will automatically shut off and won't turn on again until I plug it in. I have done the factory reset on the 20. But I don't know what to do from here. HELP
%#*@, hey can you tell me what you deleted to get the parent mode off?? I deleted the wrong files and rendered my Nabi useless!
Your tablet must have either a faulty screen or display. If there is visible damage to the screen, this may cause the touchscreen to be unresponsive. If the screen is undamaged and clean, then the problem must be the display, in which case it needs to be replaced.
Follow this troubleshooting guide to determine what the specific problem is.
You are wrong!!... problem is with the Google Play Store , reset the tablet and do not sign into the Google Play Store get your apps from an alternative app store you can download on the internet problem solved. Or you can do like me and root the tablet delete the Google Play Store and reinstall it
The real issue is in the settings you need to turn off the NFC feature then everything will work the store and all the apps will run accordingly.
Reset your device do not log into google account until you have turned off the NFC feature otherwise it will screw everything up
so when initializing it promopts you to add your google again do not add it at this time let me know if that works for you
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 1,462
