Saltar al contenido principal
La Nintendo 3DS XL 2015, comercializada como New Nintendo 3DS XL, se lanzó el 11 de octubre de 2014 en Japón y el 13 de febrero de 2015 en Norteamérica.
Preguntas 369 Ver todo
Replaced buttons, and now the 3D screen turns on, but stays black.
I removed the motherboard to get to the D-pad and to do so released the 3D screen ribbon cables, I put them back and ensured they are clean, tight and secure, flaps down. (twice- I went back and tried again after realizing the problem the first time.) and the 3D screen is turning on with the rest of the system (everything else is fine) but stays black. and tips on what I should do?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
I know you had checked many times, but did you plug in the ribbon cables correctly? Some cables' copper side are supposed to be plugged to another side of connector.
This is the only solution this inexperienced person can think of, no guarantee this will work but it's worth a shot.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
This was it for me, since all of the cables for the upper hinge get rolled up, the LCD connector was backwards. Copper facing away from you if the bottom of the board is facing towards you. Thanks so much for this comment, I would never had tried it otherwise.
- de
Añadir tu respuesta
vilanova2 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 61
