Why can't I access my keyboard while trying to text a message
Why can't I access my keyboard while trying to send a text message? The keyboard will not open
Es esta una buena pregunta?
Hi..I just went to my apps and checked the gboard app which is the keyboard i use and it needed an update and walla ..i go back to messenger and my keyboard is again working. Hope this helps! so much for automatically downloads the updates eh?
Fue útil esta respuesta?
Thank you! This also worked for me
you rock!!!! thank you so much!!!!!
me, too! Thanks a bunch!
go to settings > application manager > find your keyboard app to the download section if its is downloaded thru play store but if your keyboard is system app check it to running section and press your keyboard app then you will be directed to keyboard setting and the press the clear data button on your screen then reboot your phone if necessary..
thanks.
all section my mistake ^_^
When I use voice text when I am messaging a person on a date site, my phone all of a sudden delete it, does anyone know what’s going on
Had same problem. Go to Settings. Then Apps & notifications. Tap App info which will take you to your list. Scroll down to Gboard. . Enable! Works
This one was most helpful and to the point. I had to put gboard in search because when I scrolled down if wasnt there, but it worked!
Thank you, so much!!!
Kudos & appreciation!
I cannot find my keyboard to text on messages
I can not access my keyboard during text messaging
How do I put the keyboard back on my messages
Way can’t I access my keyboard when texting
Same problem with an older phone. Simple solution, go to app store. Voice command Samsung keyboard (mine a Samsung). There are dozens of free keyboard apps. Pick one, it will guide you thru the install. Took about 2 minutes. It works! Hope this helps.
I have a screen that covers where the keyboard should show---the actual keyboard appears as a tiny square in the top right corner of the screen
How do I close my texts when I’m done with the key?
How do I accomplish this?
Thank you?
H
What does it mean when I try to text message and send it comes up just showing the numbers between 1 0
Ultimas 24 horas: 11
Ultimos 7 días: 57
Ultimos 30 días: 288
Todo El Tiempo: 50,932
20 comentarios
cannot type on my Messenger on my phone why
- de Kalima ALI
Keyboard does not appear on my phone to send text messages
- de lee.berteit37
I am not able to type
- de Rosa Gray
I had this problem too and it kept putting hyphened or other language letters too. Re installed Google keyboard and deleted all languages except English and seems to be working like it's supposed to!!
- de Lisa Muir
@Kalima ALI
Try deleting all languages except your own and re install Google Keyboard. I just figured this out myself and it's working as it should!!
- de Lisa Muir
Mostrar 15 comentarios más
