*#06# won't show imei
when i type *#06# won't show imei
but when i go to settings/about imei is there
i have no service
Es esta una buena pregunta?
i have no service
Check your modem firmware. Go to settings,general and about and check if there are numbers there,if no numbers it means firmware is corrupted. First restore your phone and if still problem not solved then you go the hardware way. You'd have to change your base band chip which is a bit difficult.
Fue útil esta respuesta?
it's not firmware issue it's hardware
I think the baseband needs to be reballed, this is a common issue. During update or restore do you get error -1? If you do then it definently needs to be reballed.
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 3,853
i need a answer for this question too . i have more then 5 iphones same issue
- de r.o0y
do you do microsoldering
- de Adrian Zymeri
Pls help me with my iPhone 6 plus Didn't show IMEI number
- de Oluwaloniglory
