The Samsung NX Mini is a mirrorless digital camera released in March 2014.
Preguntas 7 Ver todo
Zoom lens won't unlock
I have never drop this camera or taken off the lens after first putting it on. It's been about 9 months since I had this camera. The zoom lens won't unlock after rotating it like I normally would. This has been going on for 2 months. What can I do to fix it so the lens will unlock and I can use the camera again?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
I had this problem too. I took out the 3 outer screws on the back of the lens, one seemed loose, peeked in and decided there was no way I was going to fix this thing. Screwed it back on and the camera worked again. I suspect the screws were loose. Give that a try and see if it works.
I know I was about to throw my NX-mini out when I took the chance of unscrewing it. I wouldn't try to remove the back. Just try tightening the outer screws.
Update (10/27/2017)
Update: It stopped working again.
I had a technician at work take a look at it and he found that a ribbon cable in the lens sheared. He removed the cable and it works, kind of, in manual mode. I will be sending the lens to International Camera in Chicago to have it repaired.
Fue útil esta respuesta?
Calificación 3
Comentarios:
Thanks Man. You really helped me.
por
omg thank you so much this helped
por
Its a really answer, thanks a lot brother
por
Thank you! Great!
por
Añadir tu respuesta
katiexyooj estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 11
Últimos 30 Días: 78
Todo El Tiempo: 2,585
