I changed the ink but it won't print
I changed my ink both black and tri color but my HP Deskjet1055 Printer won't print
Es esta una buena pregunta?
Hi Sharon, if your HP printer is still unable to print after recycling the Ink Cartridges, it's most possible due to improper alignment of it.
Try these steps:
Open HP print manager -->> Select setting and maintenance -->> Select align print cartridges
Now take out printed paper, you will see two dot lines parallel in red and black. Examine the alignment of the lines, click the numbers and letters for the best alignment, a dialogue box will appear to your screen, click continue, a new page will be print, now check whether these alignments are correctly printed on the paper, if you found irregularity over alignments, repeat this step 3 or 4 times to continue.
Fue útil esta respuesta?
i changed the ink and now the printer isn't working right
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 19
Todo El Tiempo: 8,378
do you get an indication light ....error sign
- de victor osaghaede
Yes on my ipad
- de sucklebuck
