Saltar al contenido principal
Modelo de finales de 2011, procesador A1278 / 2.4 GHz i5 o 2.8 GHz i7.
Preguntas 591 Ver todo
Battery did not charge, battery ondicator off, but it power up!
I have problem with my mbp 2011
Simptoms:
battery don`t charge
battery indicators off
magsafe only green
in osx it says: no battery available
if i unpluged the magsafe it goes to sleep mode.
Any ideas ?
Update (10/11/2016)
By the way, i used apple test hardware and the result are OK! I don`t find any issues. :(
Update (10/11/2016)
I have tried with a new battery but is the same issue, i have this problem after i change the thermal pasta of cpu. My question is: Mbp can run normal without battery indicator ? Or it won`t charge without this indicator cable connected ?
Thanks for answares guys !
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario
Do you mean the indicator light is not working or the indicator in the top right corner?
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Battery issues more often than not are caused by a bad battery. Replace the battery with one that you know is good, and that will tell you the answer -- if it works, the battery was bad, and if it doesn't, you know it's the computer, and we can proceed further at that point.
Fue útil esta respuesta?
Puntuación 1
your battery might of reached the end of its lifespan. rechargeable batteries have a limited amount of charge/discharge cycles
Puntuación 0
Puntuación 0
Añadir tu respuesta
sandrinilea estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 109
