Lanzado en Septiembre 19, 2014, este iPhone con pantalla de 4.7" es la versión pequeña del iPhone 6 Plus.
Preguntas 4271 Ver todo
Microphone and earphone don`t work
Hello guys!
I have big problem with my Iphone 6. When I try to call someone I can`t hear any signal or voice. The person can`t hear me too.
I tried to record something with Voice Recorder - nothing. I tried to make a video with the camera, but there is no sound. On calls I can only hear in loudspeaker mode, but nobody hears me. I tested with bluetooth watch and I can speak, but only in bluetooth.
I am with ios10, but made hard reset and downgraded to ios9.3.5, but no result.
Do you have ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
3 Respuestas
Respuesta Más Útil
It´s not a software porblem. Sounds like defective cirrus logic (audi ic) on the back of the logic board. It´s very hard to fix. You need to replace a bga chip.
Fue útil esta respuesta?
Calificación 2
Comentarios:
Hi Marius, stumbled on this post with similar symptoms and wondering if you could clarify. I have an iPhone 6 and noticed similar problems after dropping it once. I cannot hear or speak during calls unless I use speakerphone or bluetooth headphones. I cannot record audio from microphones using video from front or back, nor can I record audio using voice memo app. Bluetooth and wired headphones appear to work, is that consistent with damage to the cirrus logic board being damaged?
I would find it unlikely that all microphones were damaged as well as the earpiece speaker, so the only other possibility I could conceive would be damage to a flex cables.
por
Any water damage to the phone?
I like to start simple: change the earpiece speaker, front camera flex and Lightning port. That will replace both microphones and your earpiece speaker. Your loudspeaker is working, so you don't need to replace those.
There is a good chance the phone had some minor water damage and those components were damaged since they are the ones that have openings that water can get into.
iPhone 6 Front Camera and Sensor Cable
iPhone 6 Lightning Connector and Headphone Jack
Reemplazo del Cable de la Camera Frontal y Sensor iPhone 6
iPhone 6 Lightning Connector Assembly Replacement
Imagen iPhone 6 Lightning Connector and Headphone Jack
Producto
$24.99
Imagen iPhone 6 Front Camera and Sensor Cable
Producto
$19.99
Imagen iPhone 6 Lightning Connector Assembly
Guía
Dificultad:
Difícil
1 - 2 hours
Imagen iPhone 6 Cable de la Camera Frontal y Sensor
Guía
Dificultad:
Moderar
30 minutes - 1 hour
Calificación 0
Comentarios:
No water damages.
Everything started when I spoke with a friend in Facebook Messenger. It was OK 20 minutes and all at once he told me: I can`t hear you. I tried to recall but again no microphone. Then I noticed the problem with the earphone too...I bought the phone refurbished and since last week is mine.
por
The audio jack is not working too...
Calificación 0
Comentarios:
The audio jack is part of the same flex that holds the lower microphone. If you replace the parts Josh mentioned, that will include the audio jack.
por
Añadir tu respuesta
Nicky estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 85
