Saltar al contenido principal
Una lavadora residencial de Kenmore
Preguntas 79 Ver todo
Will not drain or spin makes a buzzing sound
How do I fix this problem if I bypassed the lid switch and it still does nothing what is the problem
Es esta una buena pregunta?
Puntuación 0
3 comentarios
Dwayne Ramon what is the proper model number of your wahser and where do you hear the buzzing? It will not spin if it does not drain. Problem could be your pump, your filter. kinked hoses and other things like the lid switch.
- de
Kenmore 800
Buzzes but don't drain or wash lower buzzing
- de
@Ron Haas
What is the model number of the washer?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Dwayne, Kenmore 400 washer will not drain or spin makes a buzzing sound.
Possibly the water pump is seized/clogged/plugged, remove water pump and check pump for debri and remove blockage. Good luck
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Dwayne Ramon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 8,730
