something will not shut down inside
After I speed cooked a baked potatoe there was a continuous noise somewhat like a grinding fan motor. At first I thought it was just cooling and would shut off. I ended up having to unplug it. I plugged back in later and was able to clear the machine but after a few minutes the noise started again. I cleared it again and ran the microwave a few seconds. It worked fine. The vent fan and lights work fine. However, when I clear the oven this grinding noise stops for a few minutes and then comes back on and will not stop unless I unplug the unit. Any ideas or is it time for a new one?
Es esta una buena pregunta?
1 comentario
Had same problem with our GE SCA1001HSS01. After unplugging unit many times the noisy fan stopped. Have not used convection since. Noise came back on own after a power blip. Had to unplug again several times and rest clock. I haven’t found answer yet.
- de epp 1948
