Saltar al contenido principal
Modelo A1312 / Mediados de 2010 / 3.2 GHz Core i3 o 2.8 y 3.6 GHz Core i5 o 2.93 GHz Core i7, ID iMac11,3
Preguntas 382 Ver todo
iMac 27 screen randomly turns off/on
iMac 27 mid 2010. Screen randomly turns off/on after OS's boot. I tried to replace the inverter board and the power supply from fine working iMacs, tried to connect it to working Macbook as external monitor, formated HDD and reinstalled with different versions macOS's, also tried the lcd display cables they seem to be fine. So the problem remains. Any ideas? Thank you!
Es esta una buena pregunta?
Puntuación 1
3 comentarios
Did this after replacement of each parts - power supply and led investor boards, and this did not help. With another invertor board screen turned off even faster after apple's boot logo disappearing.
- de
Have you solved the problem?
- de
yes, after soldering of contacts on the display matrix the display stoped to turns off at some point
- de
Agregar un comentario
2 Respuestas
Solución Elegida
When you are swapping parts out are you resetting the PRAM? Often you'll need to do this or the Mac will not accept new parts.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Also did this dozen times and nothing changed, could it be something wrong with LCD display? This iMac had lightning thunderbolt damage and had already been replaced with power supply board and worked with it about half a year
- de
Shutdown cause should be stated in Protocol system.log
https://apple.stackexchange.com/question...
Puntuación 0
Añadir tu respuesta
eLDeus estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 1,066
