Saltar al contenido principal
Lanzado el 23 de junio de 1996, modelo NUS-001, consola de juegos de 64 bits
Help with Freezing Nintendo 64
Hello, I have a nintendo 64 with the ram expander and after a random time, it freezes. I tried cleaning every cartridges and the cartridge slot but it keeps freezing. ( There is still music sometimes but the image is frozen )
Can someone help me ?
Thanks !
Es esta una buena pregunta?
Puntuación 6
Agregar un comentario
3 Respuestas
Solución Elegida
Is it an officially licensed Nintendo expansion pak? Way back when there were third party expansion paks that had a knack for heating issues and freezing problems. If it is Nintendo branded, then the RAM may be going bad. Switch it out for the original jumper RAM and see if the problem persists.
Fue útil esta respuesta?
Puntuación 8
1 comentario:
Hello , It is not an official Nintendo RAM, I tried the original RAM (the black one)and i played 30 minutes without freezing. So i think the problem is solved.
Thank you !
- de
Hey i had the same problem, luckily i had another expansion pak and swapped it and it works fine. It might be your jumper pak or expansion pak, try switching with another one.
Puntuación 0
I have the same problem. I replaced the expansion pak by the jumper pak which came with the console. Freezes do not happen as often as with the expansion pak, but still happen every ten minutes. Any idea what I could do?
Thanks!
Puntuación 0
Añadir tu respuesta
Alexandre estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 84
Todo El Tiempo: 32,187
