Charging port stopped working.
charging port stopped working. I cannot re-charge my kindle paperwhite. Has anyone had problem like this, and what can be done?
Thank you,
Sandra
Es esta una buena pregunta?
Thank you,
Sandra
Sandra, sounds like you may have a loose USB port. Charge port is soldered to a circuit board inside the Kindle that allows battery to charge. If the soldered connection breaks, the battery no longer charges. If you google your problem you will see there was a problem with Kindles charge ports.
Small computer/cell phone shops can make repair/replace charge port, get an estimate, just a guess $30-$40.00. Good luck.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 695
