Saltar al contenido principal
Anunciado el 16 de octubre de 2014, el iPad Air 2 es un sucesor más delgado del iPad Air.
Preguntas 448 Ver todo
Are Ipad Air 2 wifi version speakers compatible with the cell version?
Are speakers in the store that are available for the Ipad Air 2 Wifi version compatible with the cellular version as well? Common sense says they would be but I wanted to check to make sure before I tore down my iPad
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
The speakers should be the same, as there is no reason why Apple should make different models of the speakers for the cell and wifi iPads. If you can, compare pictures/serial numbers and see if you spot any differences, but I can say for sure that they shouldn't be any different.
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
Ok thanks. I was just making sure and I wouldn't think they would change anything
- de
*usually* iPad parts don't change between 4G and wifi. The only things I know of for sure are the obvious: the rear case, antennas and main board. Other than that, they are all interchangeable.
- de
Añadir tu respuesta
Tyler Vaught estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 35
