Saltar al contenido principal
Battery rapidly loosing charge.
The battery on my tablet is loosing power minutes afterbeing fully charged...Does it need a new battery ?
Es esta una buena pregunta?
Puntuación 2
2 comentarios
Ce0168 Samsung battery EB_BT561ABE
- de
I want to buy a new battery model by that number please. thanks
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Hi,
You are probably correct. The battery is most probably failing. Even rechargeable batteries have a life span.
Here is a link to the Ifixit guide that shows how to replace the battery in your tablet.
Remplazo de batería Samsung Galaxy Tab 3 7.0
To obtain a new battery just search online for a Samsung galaxy Tab 3 battery to find suppliers
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
Just went to 5 different retailers here in Brisbane and was told to throw it out.. None of them would open it or could replace the battery...I think this model is out of production.
- de
Hi, It is out of production, but if you try places like Ebay you can pick up a new battery for around $18-$30. Just make sure you have the tablet's 'exact model number' to get the right one.
http://www.ebay.com.au/sch/i.html?_odkw=...
Then you can fix it yourself. If you like the tablet this is a cheaper option than buying a new one. Your call
Hint : If you don't have a 'pry tool' to open the case try using the corner of an old credit card. Being plastic it will not damage the case as does a metal tool. A purpose made 'pry' tool which is also available on Ebay is easier to use obviously.
- de
Why does it say I need a new case back? Does the procedure destroy the old one?
The one shown isn't the same as mine—the lens hole is on a short side (shown) instead of a long side (mine). That makes me wonder if the rest is accurate for my unit, which has CE0168 on it, just like the one shown.
According to Settings>General>About Device, I have an SM-T520. Will these steps still work?
- de
Hi @monageng
Search online for EB_BT561ABE to find suppliers that suit you.
Puntuación 1
Añadir tu respuesta
rdaw1958 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 751
