El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3789 Ver todo
iPhone 5s doesn't show that it's charging when its off
I was repairing an Iphone 5s. After I took the bottom screws out and lifted the screen,I was in the process of removing the metal shield from the battery cable.I used metal tweezers instead of the plastic sponger.Big mistake because I saw a small spark fly. I detached the battery,then held the power button for 30 seconds before reconnecting the battery.(In which the dead battery signal came on the screen).I then disconnected the battery and went moved onto the screen repair. Once I put the phone back together,I put the phone on charger.(At this point it is showing the dead battery signal.) I left it there long for about 5 minutes before the phone booted itself up. I tested everything to make sure everything is working, then I let it charge about 20 more minutes while connected to my laptop.The problem that I'm having is,the phone works fine,but when it is on the charger and turned off,it gives no sign of charging. If the phone is on while on the charger,it shows the lightning bolt by the battery at the to of the screen signifying charging in process. But when it's off,(though it's charging) it shows nothing but a black screen.Sorry so long, I just wanted to make make sure I included all details. Any help would be appreciated.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
So it charges, it just doesn't show a charging icon when the phone is off?
por
Yes,that is correct,Josh
por
Funnily I always use nails to unplug connectors. Always worked out the best for me. The only time I ever use a plastic spudger is if there are so many ribbon connectors to unclip like htc one m9.
por
Agregar un comentario
¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
Visita Nuestra Tienda
¿Alguna vez arreglaste algo? Eso es genial.
Comparte tu historia de reparación con #SoyUnGenio
Todos somos Genios
2 Respuestas
Solución Elegida
Probably blew a filter. Its not an easy fix and its not a cheap fix to have someone else do. If it were me, I'd leave it be as long as its charging, holding a charge and not heating up
Fue útil esta respuesta?
Calificación 1
Comentarios:
That would be a motherboard repair???
por
Yes.
+chartoletmepost
por
My s6 does the same thing but it's new is it supposed to show a charging sign when it's off
Calificación 0
Añadir tu respuesta
Ungandua estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 29
Todo El Tiempo: 1,349
