F250 ranger isn't turning over
First it would crank as soon as I put the battery in replaced starter and solenoid and ignition now I have power to lights and radio but it won't crank
Es esta una buena pregunta?
Quinn, check ignition fuse, all clean all connections including grounds and check wires for corrosion,tight, undamaged. Check and test battery, safety neutral switch, starter and solenoid for proper operation. Many parts suppliers offer bench test for these components. Check the attached links,instruction and guides, Good luck
https://www.youtube.com/watch?v=uGGTaOQk...
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 338
