Saltar al contenido principal
El iPhone 5c de Apple fue anunciado el 10 de septiembre de 2013. La reparación de este dispositivo es similar a los modelos anteriores, y requiere destornilladores y herramientas de entrometimiento. Disponible como GSM o CDMA / 8, 16, 32 GB / Blanco, Rosa, Amarillo, Azul y Verde
Preguntas 1225 Ver todo
iPhone 5C battery drains fast
I have an iPhone 5C it works great but I noticed that the battery is draining fast. I thought it was normal because it is an older phone and running new iOS. I tried putting it in low power mode but it didn't help. I charged it to 100% and without being used its dropped nearly 40% battery. It was on 88% and I powered it down and waited about 5 minutes and turned it back on. It was at 80%. I tested the battery with my computer with the Coconut battery application and it says that the battery is good and at about 80+% capacity. Anyone know anything about this or how to fit it?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Comentarios:
Have you replaced the battery yet? Do that first, and then see if it improves.
- de
Agregar un comentario
5 Respuestas
Respuesta Más Útil
Hey Chad!
When I've seen this, it's usually due to a few things:
1. Too many apps running.
> Double tap the Home button
> Close out all apps running in the background
2. Too many apps allowed to run Location Services - Always.
Go to Settings > Privacy > Locations Services
> Look to see which apps you want running: Always / While Using / Never
3. Battery is getting old and needs replacing.
> iFixit - iPhone 5c Battery Replacement Guide
> iFixit - iPhone 5c Replacement Battery $24.95
> ebay $6.00 - $7.00
If you haven't already, go to Settings > Battery. Scroll down to see the Battery Usage over the Last 24 Hours & Last 2 Days. That may help give you some more clues what's consuming the most power.
Warm regards,
Anthony
Imagen de iPhone 5c Battery
Producto
iPhone 5c Battery
$29.99
Fue útil esta respuesta?
Puntuación 3
download ibackup bot, handy tool shows how many charge cycles your iPhone has been through, once connected it looks in the most recent iTunes backup of your phone which iTunes saves this info and hides it from the customer, this is a little secret getter. :)
Click on More information and it will give you a very detailed report
Iphones usually hold 350-600 cycles and at 400 cycles they retain 80% of their life
  • Each Cycle is from 0 to 100% that is 1 cycle, charge from 50% to 100% is a Half Cycle** so 400 charge cycles would be 400 charges from 0% to 100%
----Make sure you do a backup of your iPhone in iTunes for the most recent info----
http://www.icopybot.com/itunes-backup-ma...
Example with my iPhone:
Puntuación 1
Replace the battery and test it.
Puntuación 0
I had the same problem.
There are things you can do to prevent the rapid battery drainage (which you can research: how to prevent battery drainage) but you are probably going to need to do a battery replacement.
So I recently had my battery replaced at Apple Doctor and I noticed the battery kept draining quickly even after the battery had been replaced. I called the technician that had worked on the phone and told him that the battery was still draining way too quickly he suggested that I let the phone drain to 0% and then put the phone on charge for 4 hours if it is still getting depleted too quickly then it is a problem on the main DV board and that can’t be fixed unfortunately. After I did that and did a hard reset the battery seems to be working fine again.
It is also worth mentioning that the technician also told me once your phone’s overall charge capacity drops below 80% your battery definitely needs to be replaced.
i’m no professional but I hope this helps.
Puntuación 0
i wouldn’t rely on just coconut battery. ive had batteries where they read 100% but when you put them top real world tests they ended up being closer to 75ish%. swap the battery and let it sit on charge for a few. also try a few of those other tips. background apps kill batteries and so do location services,
Puntuación 0
Añadir tu respuesta
CAB estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 6,845
