Saltar al contenido principal
Modelos de MacBook Pro con una pantalla de 15"
Preguntas 8252 Ver todo
do you need to apply thermal grease to cpu chips?
Do you need to apply new thermo greese to cpu chips and heat sink rails when replacing logic board? i replaced logic board and everthing works great but just worried i should have applied new thermal greese to cpu chips. thanks
Update
ok no worries thanks for yout help . will def go and do it now.. many thanks
Es esta una buena pregunta?
Puntuación 4
1 comentario
No Prob, try Artic Silver 5.
- de
Agregar un comentario
3 Respuestas
Solución Elegida
Here is our Generic Thermal Paste Guide, which should help you properly apply thermal paste. Doing it right is very important to avoid overheating issue later in your computer's life cycle.
Fue útil esta respuesta?
Puntuación 6
1 comentario:
Yes, you should have applied thermal paste to the CPU. I always recommend that Posters replace the original Thermal Paste that is on the CPU being that Apple uses cheap thermal paste, and it is usually applied very poorly.
Puntuación 3
2 comentarios:
+ I use Artic Silver also.
- de
many thanks, applied artic sliver as deminstrated in thermal paste guide. works so well sceems to run heaps cooler 2. thanks again
Puntuación 0
Añadir tu respuesta
Kurt Russell estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 4,336
