Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Pantalla de 4 pulgadas / Disponible en una variedad de colores / Lanzado en 3 modelos diferentes / Capacidad de 16, 32 o 64 GB
iPod Touch 5th Generation
So the problem with my iPod is that it won't charge like for example ur battery is at 20% it would stay there it won't charge at all I don't know if it is my charger or its my iPod
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Hi,
Without knowing more details about your ipod (if you dropped it, spilled water on it, bent the charging port etc), these are my suggestions:
The first thing to try would be a different charger and a different outlet, to ensure that those are not the culprits.
Batteries do have a limited life span; after a certain number of charges (~2000) they will start to fail until they eventually can't hold a charge anymore. You could be due for a battery replacement. This guide, up through step 16, outlines how to do this.
Reemplazo del conjunto de placa lógica del iPod Touch 5ª Generación
You could also have an issue with the charging port, a replacement is outlined here, through step 27.
Reemplazo de la carcasa trasera del iPod Touch 5ª Generación
Good luck!
Imagen de iPod Touch 5th Generation Conjunto de Placa Lógica
Guía
Dificultad:
Difícil
1 - 3 hours
Imagen de iPod Touch 5th Generation Carcasa Trasera
Guía
Dificultad:
Difícil
Fue útil esta respuesta?
Puntuación 5
1 comentario:
Great answer! You need some more rep!
- de
I think you should check your charger on another apple device to see if it charges that and if it doesn't its not your ipod its your charger
Puntuación 0
1 comentario:
This has already been resolved and accepted.
- de
Añadir tu respuesta
Zubair estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 188
