Power but no sound on tv on my 55 inch
I have a 55 inch led hdmi digital TV and the volume turns down by its self , and remote doesn't work when the TV does this . I tried to use the buttons on the tv, but that did not work . I also tired unplugging and holding the power button on tv . That seemed to work temporarily, but then it happened again . What can I do to fix it ? Please help. Thank you.
The model number is fw50d36f.
Es esta una buena pregunta?
5 comentarios
what do you mean by volume turns down by itself, like you can see the dialog box and the volume going down or just no sound?
- de echow2001
Hi,
Try taking the batteries out of the remote and see if the problem occurs. You may have a sticking Volume down button in your remote.
- de jayeff
The dialog is up in the left corner and u can see it going down fast . I did think the same thing about the remote but I took out the batteries n turned the TV up with the bottom on the TV a few minutes later it was at 0 .
- de Carolyn Brandt
@cookiemonster38 sounds like a bad button board. the problem is going to find a replacement.
- de oldturkey03
Thank u all for ur helpful hits I am going to try the button board n see if that fixes the problem
- de Carolyn Brandt
