Saltar al contenido principal
Modelo A1200 con procesador Core 2 Duo de 2.16 o 2.33 GHz
Preguntas 113 Ver todo
Is it possible to replace the graphics card into a better one?
Hi, thank you for your great work.
I would like to know if it is possible to change the graphics card of my iMac, so that, for example, I can use the OpenCL technology in Mac OS X 10.6. I know from MacTracker that the graphics card connector is MXM.
If it is possible, how? Thank you.
Appleman
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
6 Respuestas
Solución Elegida
I ordered the card from weloveMacs.com. I had the nvidia 7300 with only 128MB memory. I ordered & installed the NVIDIA GeForce 7600 GT VRAM 256MB Video card for $299. It was about $338. Withbexpedited shipping. I did take some pictures that I could send you with comments if you like. I had replaced the HD on this machine before. That was fairly easy. Everything I read about this video card swap made it sound particularly hard and daunting. It really was not.
Yes, the profiler recognized it immediately. My screen is brighter and my games are much faster too. The whole machine seems faster.
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
This is just great! Thank you really very much.
- de
Could you send us the pictures? Thanks
- de
+ Please send pictures and a description or better yet, contact milo@ifixit.com to set up a guide on this. I would like to do it.
- de
Respuesta Más Útil
it might be physically possible, but I've not heard of any great selection of cards that would fit this model, although I've seen at least one place advertising iMac graphics cards (but expensive!!) Not 100% sure cards other than the standard 7300GT and 7600GT would work with this model iMac, I think you may have to also worry about drivers?
Puntuación 2
1 comentario:
Thank you very much! I think I will stay with my 7300 GT :)
Appleman
- de
Yes it is possible. I just replaced my ailing 7300 with a new 7600 and it works great! The card and it's thermal channels are at the front of the machine, right under the motherboard, so it is a complicated repair, but well work the labor. I saved about $500. doing it myself.
Puntuación 1
1 comentario:
Where did you get the part? How did you put it in? Does the system profiler recognize it? Did you take any pictures?
- de
I'll add a few pictures with notes tomorrow or Friday.
Puntuación 0
I too just replaced a failing 7300GT 128MB with a 7600GT 256MB card. I found upon disassembling the iMac that the heatsink mounting screws had come loose, causing the card to overheat and fail.
An interesting side note is that the iMac used to have a faint screen burn-in covering the lower half of the display. After replacing the graphics card, the burn-in is gone! :)
Puntuación 0
My graphic card 7300GT is going bad... Would that be possible to replace it my self?
Puntuación -1
1 comentario:
please start your own new question
- de
Añadir tu respuesta
appleman estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 13,182
