Machine not pouring the coffee after it heats up?
Why is it not pouring the coffee after it heats up?
Es esta una buena pregunta?
you could have a clog in the tip needle where the coffee goes check that first..
unfold a paperclip and stick it in to the needle then try it again. you may need to dig a little if there is a lot in there
Fue útil esta respuesta?
Thank you! I haven't been able to use my Keurig for the past couple days! My mom used fine coffee grounds and it went up and clogged the needle, but after clearing it with a toothpick it started brewing again!
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 655
