Released on September 19, 2014, this 5.5" screen iPhone is the larger version of the iPhone 6.
Preguntas 1263 Ver todo
Why does my Isight Camera Shake & make an Audible clicking Noise
I succesfully completed at the beginning of July replacing my cracked screen. After purchasing an iPhone 6 Plus LCD Screen and Digitizer Full Assembly Fix Kit with isight camera from Ifixit, my phone was back up and running. I've been using my Isight camera for the last month or so without any issue until today. For no reason i.e. Havent dropped, knocked or damaged the phone, my Isight Camera has began shaking & making an audible clicking noise. This only occurs when the phone is held in horizontal position and with any photo app.
Is this issue related to hardware or software and has anyone experienced, rectified this fault?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Comentarios:
Whats an 'Isight' camera? No idea what that is. Is it front or back camera?
por
Ben, iSight is the name Apple uses for the rear-facing camera on i devices
por
Okay, sounds like a hardware fault on the rear camera. Possibly not mounted properly with the screw and metal bracket.
por
Thanks Ben.
Glad to know that its hardware and ill try your advice to see if thats the issue.
I also read that Apple has an Isight camera replacement program for certain Iphones and my phone's serial number falls within the eligible criteria.
Do you know if by having replaced my screen that voids their assistance?
por
Yep pretty sure that voids warranty. They most likely can tell if the screen is aftermarket or it has been opened before.
por
Mostrar 2 comentarios más
Agregar un comentario
1 Respuesta
Solución Elegida
You voided your warranty when you replaced your screen. Very common issue with the rear camera, you just need to replace. Takes like 5 minutes. Make sure to not over tighten the camera cover.
Fue útil esta respuesta?
Calificación 3
Añadir tu respuesta
Santiago Dominguez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 18
Últimos 7 Días: 139
Últimos 30 Días: 481
Todo El Tiempo: 29,843
