iPhone no sound, black screen, no vibration when plugged in
I dropped my iPhone and it has a black screen, doesn't make any sound, doesn't vibrate when plugged into the charger. But when i plug it into iTunes it recognizes my phone and it shows that my phone can still charge. DO you guys thin my screen and digitizer is broken or my logic board. Like when i plus it into my computer, my computer makes a sound instead of the iphone, and when i hold power and home when plugged into the comp for 10 sec, it makes another sound.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 4
Agregar un comentario
2 Respuestas
Respuesta Más Útil
might be stuck in recovery
try using the mute switch to see if it vibrates when switching.
if it vibrates then its a screen issue. if not then its in recovery.
Fue útil esta respuesta?
Calificación 1
Comentarios:
it doesn't vibrate
por
does itunes say its in recovery or does it say the entire phone info like normal? if its normal then the phone might be disabled or some how the vib is not working.
por
how can i exit on the recovery mode?
por
recovery mode will automatically restart to normal operation after period of time reboot on its own. but you can always hold power and home to do a normal restart that will start a normal boot sequence.
por
I have the same problem!
after a very very small stroke the screen turned black, no sound, no vibration. but itunes recognizes it but I can not access it because I can not put the pin and make a backup. do you think you disconnected the connector? the technician told me the faulty display. But the vibration and the sound that do not work? are all connected to the screen???!
thank you
Calificación 0
Añadir tu respuesta
muning estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 21
Últimos 30 Días: 66
Todo El Tiempo: 1,918
