Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3530 Ver todo
Unable to unscrew 1.2mm and 1.3mm Philips #000 screw.
I have the Philips #000 screwdriver from iFixit.
However, I seem to only be able to unscrew the 1.7mm screws. No luck with the smaller 1.2mm and 1.3mm screws. I am currently at this step.
Is this the expected scenario ?
Thanks in advance :)
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Have you tried a little bigger driver? I normally use a 00 driver on iPhones.
Fue útil esta respuesta?
Puntuación 3
5 comentarios:
Dang, I do not own a #00 driver. Will try to obtain one and see if it works.
- de
Thanks for the info, I've been using #0 Phillips head on iPhones which is probably not optimal.
- de
I got the screws out, used a screwdriver that I borrowed from a friend. Kinda disappointing that the ifixit screwdriver does not work..
- de
Yeah sometimes I have to use the german phillips head screw driver that pretty much never gets worn out and works for philips head phone screws that are hard to take out.
- de
i am having the same problem. Which screw driver did you get from your friend?
- de
Añadir tu respuesta
Daylen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 2,597
