Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Segunda generación de iPhone. Modelo A1241 / 8 o 16 GB de capacidad / plástico negro o blanco de nuevo. La reparación es más sencilla que el primer iPhone. Requiere destornilladores, curvas y herramientas de succión.
Preguntas 1508 Ver todo
How do I change my iPhone 2nd Generation battery?
My battery in my 2nd generation iphone dies extremely fast. How can I change it so i can actually use my phone for more than six hours?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Comentarios:
is it a 2g or 3g you have?
- de
Agregar un comentario
Kits para Nintendo Switch
Una solución rápida para volver al juego
Comprar kits de Switch
1 Respuesta
Respuesta Más Útil
The iPhone 3G has been shown to exhibit poorer battery life than its predecessor when persistently utilizing 3G connectivity. However, some have reported inordinately short battery life, which could have a variety of causes including:
faulty battery indicator
overactive Push mechanism
application flaws
hardware defects
If you think you're suffering from unusually short battery life, try the following procedures:
Turn off Push The iPhone 3G's Push functionality for Exchange and Mobile Me accounts can destroy battery life. Turn this option off in "Settings" and compare your new battery life to the old.
Force-quit applications If an application quits unexpectedly and you notice poor battery life afterward, relaunch the application then force-quit it by holding down the home button for several seconds. This can eliminate problematic or hung processes that might be draining the battery.
Reset iPhone In some cases, simply resetting the iPhone can resolve signal strength issues. Hold down the home and sleep buttons simultaneously until you see the white Apple logo, indicating that your iPhone has restarted.
This procedure can right a faulty battery indicator and eliminate applications that have hung or are otherwise improperly chewing battery.
Reset network settings Tap Settings, tap General, tap Reset, tap Reset Network Settings. This will cause your iPhone to restart, and will delete any stored Wi-Fi passwords as well as DNS settings and more. It can resolve signal strength issues in some cases.
Here's how to replace the battery: iPhone 3G Battery Replacement
Here's the part you need: iPhone 3G Replacement Battery
Here's some information on extending your battery life: http://www.iphoneincanada.ca/tips-tricks...
and the search: http://www.google.com/search?client=safa...
Imagen de iPhone 3G Replacement Battery
Producto
$14.99
Fue útil esta respuesta?
Puntuación 1
Comentarios:
- de
Añadir tu respuesta
Jordan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 3,437
