TV has power, but no video
So I am trying to troubleshoot a insignia tv. There is no video, the screen stays black. When I turn the tv on or off the light on the tv changes, so there is power. I also tested the cables on the boards and they all have power going to them. There is three boards, one that is power and the ac adapter plugs into, the other one is where the hdmi Cable and other cables plug into, and the last one plugs into the screen.
How do I yroubleshoot the tv and figure out which board is bad or if it is the screen?
If there is any other information you need please let me know
Es esta una buena pregunta?
9 comentarios
I did use a multimeter and test the power on the boards and there is power on the tv and to every board. You are saying the LED board, which board is that? Is thag the board thag plugs into the screen?
Also, is there are way to verify that this is the problem? Or if it is the screen itself?
- de Jetlabb Electronics
Ok, my issue is similar........I have no picture but perfect sound........Mary
- de Mary Hedrick
I purchased a new LED board (I think that is the one, it has all of the plugins like HDMI) and installed it and there still wasn't a picture. I have a new power supply board on its way and a new T-CON board on its way just in case. Will update you guys and let you know!
hey did the new power suppy board work for your tv? i am having the same problem with my insignia right now. black screen but perfect sound... i think its the led driver/power supply.. im not sure tho? anything work for anyone else?
- de tonik128
I had the same issue and just finished fixing it. There was one LED out of 66 in the back-lighting that was bad and caused all the backlights to go out. I was able to find a replacement back-light strip on Ebay for $20 and installed it myself, now the TV works good as new.
- de Bob Casabella
Mostrar 4 comentarios más
