Head light not turn on
The head light for my Ford Expedition is not on..I change the light Bulp and still don't work
Es esta una buena pregunta?
1. Check Fuse
2. Check Connection (Wiring)
3. Check Switch
Fue útil esta respuesta?
There are separate fuses for each headlight and I believe they are in the interior fuse panel. It is on the right side of the instrument panel. If the fuse is fine, check the ground wire and the low and high beam wires at the connector. These steps should pin down the problem. Good luck!
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 136
