adhesive strips tore before I could remove battery, now what?
Adhesive strips tore before I could remove them from the battery, how do I remove them now?
Es esta una buena pregunta?
Gently pry up on the end of the battery closest to the charging port, use a small pair of tweezers and grab the loose end of the strip and gently pull on it. I find that spinning the tweezers to coil the strip up on the tweezers helps a little bit. Take your time and pull gently and they will typically come out easily, but don't feel bad, I have broken several hundred of them and they always come out with a little patience.
Fue útil esta respuesta?
Thank you for the help, it's greatly appreciated!!
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 57
